clutch question
Old Nov 1, 2007 | 11:08 AM
chipmonk's Avatar
Originally Posted by firecrazy720
how do I find out what tranny I have.
what year truck do you have? '05.5+ ctd's used the g56- reverse is next to 2nd (down and to the left).
Old Nov 1, 2007 | 11:16 AM
scootertrash35's Avatar
Originally Posted by VFDFireman
Not to high jack the thread, but what can one expect to pay for a single disk installed?
i paid $750 for clutch,$200 for hydraulics,and 3.5 hours labor,total $1,234
Old Nov 1, 2007 | 11:48 AM
stock600's Avatar
is the [hyd. upgrade manditory or recommended] the pedal feel is close to factory, any one tryed the centerforce, the idea of the light pedal but increased holding power at higher rpm due to the centrifical wieghts sounds like a good idea, i need one pretty bad just cant make up my mind either. i used to make 46+ lbs want even hold 30 now.
Old Nov 1, 2007 | 12:01 PM
chipmonk's Avatar
for g56 the hydraulic upgrade is mandatory. imo the centerforce is not in the same league as even the sb stock hp clutch- if you're going to do it you should do it right and sb is the path to clutch happiness.
Old Nov 1, 2007 | 12:27 PM
stock600's Avatar
got ya, same story as every one else must be that good, my mind is made up on the sb con ofe, dont know my hp or tq. numbers but by boost readings i think ill be 450-500 range sure the ofe is up for it do you know what the rate it for? for my driving the fe is prob. ok i hear its jerky somewhat, i dont drive in traffic very much, how jerky is it, and is it still friction material all the way around or those little pucks?
Old Nov 1, 2007 | 12:32 PM
dodgezilla04's Avatar
the ofe is rated for 450hp.
[IMG][/IMG]
there are many factors as to how much a clutch will hold. driving style, usage, how fast the power comes in, etc.
these CR motors make so much tq at low rpm, you can easily overwhelm a clutch if you arent using your head.
my ofe has lasted a year now, with about 15 dyno runs, all over 500 hp, 1 sled pull and a bunch of hotrodding. but i do not slip it or ride the clutch.
Old Nov 1, 2007 | 12:57 PM
stock600's Avatar
thanks, sounds like you def. have more power than me and im very happy with what i have and no intention to upgrade ,power that is, im easy on a clutch so sounds like the ofe is the right choice, i still have the extreme seeting on the ppe ive never tryed so when i get clutch in i still get a big upgrade waiting for me! thanks someone sugg. buying from here, wheres it located and price also heared members get a discount is this true? thanks
Old Nov 1, 2007 | 01:02 PM
DTR members get the best pricing - - 304-952-6896
call and talk with lary at the dtr store. sbc products are not listed in the store, but lary has them.
Old Nov 1, 2007 | 01:20 PM
stock600's Avatar
thanks ill give him a call.
Old Nov 1, 2007 | 01:59 PM
snoyes's Avatar
Also if I can suggest you to call Peter at South Bend Clutch. He was a nice guy, knowledgable... will help make the final final choice....
Old Nov 1, 2007 | 02:11 PM
stock600's Avatar
whats dd clutch in your sig.
Old Nov 1, 2007 | 02:30 PM
snoyes's Avatar
Dual Disc... Probably a little more than you need (and I need), and the pedal pressure is significantly more. However, longevity and the huge amounts of power you can push with these clutches are amazing.
Old Nov 1, 2007 | 02:42 PM
stock600's Avatar
ok, yea i prob. will only need the single disk, ofe . with your dd i bet you can use your smarty to the fullest, this will be fun, ever ran yours in the 1/8?
Old Nov 1, 2007 | 03:27 PM
snoyes's Avatar
Yep, but the extra time it takes for me to disengage and re-engage the clutch actually cost me time. But again, with the handshaker, I guess I didn't by the truck to drag race... But catch me on the highway in fifth/sixth, and on level 9 this things pulls...
Old Nov 2, 2007 | 04:24 AM
chipmonk's Avatar
do you have the 3250? if so how is pedal pressure, towing, and grabiness? peter could'nt say enough about it but man the price!
