Checking for codes
Old Sep 22, 2006 | 07:36 AM
Foxborough's Avatar
Checking for codes
Sorry in advance. I did a search and did not find an answer, I must be stupid. With the changing weather last spring I would get a CEL once for the battery and once for the air rational. Today with changing weather CEL came up. I tried to cycle the key and for the life of me cannot get the code to come up. I am doing something wrong. All I get is "-----". should'nt it say done? I cycled from off/on/off/on/off/on with off being the place where you could pull the key out on being where the engine lights come on. I also tried cycling from the spot where all you see is the transmission selector & odometer as the off position. I was able to do this 6 months ago and now can't.
Old Sep 22, 2006 | 07:56 AM
P.J's Avatar
P.J
You need to end up in "on", not started, just on.
They should display.
Just on, off, on, off, on.
Old Sep 22, 2006 | 08:11 AM
Foxborough's Avatar
Yes that is where I leave it at "on" -- (not starting).
Old Sep 22, 2006 | 08:26 AM
P.J's Avatar
P.J
Huh?
Dunno then. Take it to an Autozone (or comparable) they will read the codes for you.
Old Sep 22, 2006 | 08:30 AM
Foxborough's Avatar
Could it be that the code has been cleared and that is why I get "---------" in the odometer. I always thought it would say "done". Or is that only when a code comes up? Sorry for rehashing this, I have forgotten some of the procedures. I should be sent to my room without supper.
Old Sep 22, 2006 | 09:01 AM
Foxborough's Avatar
Thanks. I will see if the light come on during lunch. I'll take it to AutoZone and see if they can see the code. I have to go into chicago later today and want to make sure nothing is wrong.
Old Sep 22, 2006 | 09:13 AM
P.J's Avatar
P.J
My 01 used to say "P-done" (at least).
Old Sep 22, 2006 | 11:52 AM
Foxborough's Avatar
Went to AutoZone and read it. P0071 air temp rational. Must be that time of year. Went ahead and bought the Actron AutoScanner. Only $106, now the light will never come on. Thanks for the help P.J .
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tacohat
Jul 17, 2006 02:27 PM
DarrellB
Sep 6, 2003 04:49 PM
