changing transfer case fluid.
Old Oct 20, 2009 | 11:51 AM
klx650a2's Avatar
On my 2000, the fill plug was stuck and WOULD NOT come loose. 2 weeks of penetrating fluid soaking would not touch it. Had to use heat and an impact got it loose, but it could have been a bad day because the drain came loose without a problem.
Old Oct 20, 2009 | 11:55 AM
tool's Avatar
I had a crack in my transfer case and was having to constantly add fluid until I could get it fixed.
I ended up tearing the corners out of the fill plug and had to weld my 10mm hex socket to the plug so that I could continue to remove it and refill.
Whoops
Old Oct 20, 2009 | 11:56 AM
05HDRAM's Avatar
I wouldn't wait till 60K. I changed mine at 25K and it was some nasty looking fluid.
Old Oct 20, 2009 | 01:38 PM
Dr.Dizzle's Avatar
I would not wait to replace the fluid at the 60k interval either. I replaced my fluid early on, in order to get the wear metals or "break in" materials out of the unit.
Old Oct 20, 2009 | 04:52 PM
bansh-eman's Avatar
Same. I did mine at 25k and there was quite a bit of metal shavings on the magnet. I am getting ready to do it again at 45k (2k more miles). Same with my T-Case.
Old Oct 26, 2009 | 03:39 PM
DBLR's Avatar
Got 34K on mine so guess I need to get it changed out ASAP.
Old Oct 28, 2009 | 11:10 PM
bansh-eman's Avatar
Just did my 2nd chang on my tranny today. Fluid looked nice and clean, only a little bit of metal on the magnet. Going to do the T-Case and oil tomorrow (if it doesnt rain again)
Drafter
Feb 1, 2006 12:21 AM
Original Junior
May 16, 2005 04:04 PM
coadman
Apr 11, 2005 01:02 AM
BigBlue
21
Aug 3, 2004 03:13 PM
