Changing Filter and Separator on an Airdog FP100
I'm going to be changing both the fuel filter and the water separator on my FP100 soon. I notice that when draining the separator it will keep draining until I turn the cap closed again (it doesn't seem to 'empty'). So my question is... Am I going to turn my garage into a hazmat site when I try to replace both items - i.e. will fuel flow out of both locations freely until I can get the new items screwed in place?
I tried calling Airdog about it, but, sorry to say, my experience with them returning calls has been less than stellar. Don't get me wrong - I like the product, just not the support...
Thanks -
Thanks -
mine does the same thing even thought its a AD165. I put a vicegrips on the in line to keep the drain low. Take off the separator with a oil pan below, using the fuel dripage, I refill the separator screw back on. Then I do the filter. There is a little dripage from the filter, but not a constant drain.
A stupid question...
I have an Airdog coming this weekend; I've looked through the install manual online and it recommends capping/plugging the stock canister/pump at the intak/outtake ports? Huh? Are they saying to remove the canister/pump? Or the hose hookups on the canister/pump? What about the stock hoses that go to them? The AD will connect to the CP3 by way of a banjoe bolt. Or am I missing something?
truckjunkie
Mar 4, 2010 03:30 PM
GaCamper
Jan 11, 2009 07:05 PM
67HotRod
Jun 13, 2005 08:01 AM
