AirDog FP100 install ??
just got the fp100 in the mail and was flipping through the install manual and it seems that the edge chip cant be wired into it to show fuel pressure i thought that some guys were saying they were monitering there fp with this set up. is there a way to do this or do i have to run the idiot light. the airdog comes with a replacement for the banjo bolt removing the stock fuel line and banjo but the system 90's into the new fitting. anyone thats installed a fass and has set up fp monitor i could sure use some help.
on my 150 there is a plug/fitting (allen key) that can be removed, you can screw in your sender to read your fuel pressure, pretty sure it's in the inst manual, under optional low pressure fuel light.
I installed the fp100 a couple months ago and encountered the same problem. I ended up buying a 90 degree push lock fitting w/ a 1/8 npt threaded hole to get a fuel pressure reading. They sell the part at Vulcan Performance: http://www.vulcanperformance.com/servlet/StoreFront
truckjunkie
Dec 29, 2010 04:45 PM
truckjunkie
Mar 4, 2010 03:30 PM
kdbvulcan
20
Dec 6, 2008 04:34 PM
