Be careful with oil containers
I bought 3 gallons of Rotella T for my upcoming oil change.
The other day I changed my fuel filter and opened one of the gallon jugs for a dab of fresh oil to lube the fuel filter gasket.
Then put the oil jug back on the rear floor.
Well today I had a coke rolling around in the back*quadcab) and when I picked it up there was oil on the can. To my horror I saw the jug on its side.
I picked it up and the oil level was down two quarts!!
Yup two quarts of oil is soaked into my carpet. I used a 10" piece of plastic to squeegee out as much as I could. Live and learn! check the caps!!
OH LORD, I would of blown up. I get angry seeing crumbs all over my backseat.
You might want to try getting that throughly steamed cleaned, I'm sure what is already soaked in is not comming out but it wouldn't hurt to try. Do you have Black carpet?
This sortive reminds me of the post on here a while ago about some guys wife leaving shrimp in their car for a few days, all the juices soaked in the seats. Im sure that wasen't fun either.
I have drained used oil into those gallon jugs before and put them in the back of my truck. One overturned and the whole cap popped off.
Lesson: Burn used gallon jugs before anyone can use them again. Once the seal is broke, they are absolutley worthless.
What a shame, I feel so bad for you!
I bought the 1 gallon Rotella from Wal-Mart a couple oil changes ago, and when I got it home, the seal was missing from both gallon jugs! I returned them for two good ones, and the girl at the return desk looked at me like I was crazy! Never know what may have dropped in those jugs.
I know this may sound crazy, but you may want to spread some fresh cat litter on the spill. It absorbs like crazy, and vacuums up without a problem. I use it in the shop, garage, and driveway all the time. Might be worth a try...good luck!
Hey, atleast it was oil. That stuff does not rot and smell like dead roadkill like milk does. The previous truck had about 1/2 gal of milk spilled in the back floorboard carpet. Should have smelled that baby a week later........
Go ahead and pull the sill plates on whichever side the oil drains to. You'll find that the ridges under the sills are full of oil as it would run to the side, then along the length of the door.
The 2nd gen carpet has a rubber backing underneath it (hoping the 3rd gen does), so most of the oil works its way out of the carpet to the sills. Although you'll still have to work to get the stuff the carpet soaked up clean. Don't ask how I know.
You put oil IN the truck? Fresh oils goes into the Engine "outside" the truck, then you drain the old oil "outside" the truck. You put used oil inside the truck??
That does suck, about the only thing I would say that works good (they use it on oil spils on the road, and for big oil tankers) use dawn. Scrub dawn into the carpet, vacume, use some water and dawn, vacume, best way to get it out (not that I know what it's like
) Works very good, and it's not as harsh as using brake cleaner, or some of the other ones. I can't even imagine that
Like others said, used oil would have been bad
Typical Newbie mistake, putting oil in the wrong place... better the carpet than the Coolant Hole, Washer Hole, Brake Hole, Clutch Hole, Tranny Hole, or Rearend Hole
Some have reported putting oil in the Fuel Hole with good results...
Hub
One time I bought 4 bottles of mobile 1 diff fluid and the some jerk put old unknown oil in the bottle.I go and put it in my diff alittle spills out and it's used dirty fluid,I went back to auto zone a little upset
