can't retrieve codes
Old Oct 30, 2007 | 11:40 PM
dieseljrs's Avatar
tried to retrieve codes using key method. Nothing came up in the odo. screen. The only thing that happened was the check engine light flashed 10 times. Any ideas on whats going on ? check engine light is on.
Old Oct 31, 2007 | 08:05 AM
Dale_K's Avatar
Do it faster. I had trouble until I figured out I was doing it too slow.
Old Oct 31, 2007 | 08:30 AM
dieseljrs's Avatar
tried it doing it as fast as i could. still nothing
Old Oct 31, 2007 | 02:26 PM
Dale_K's Avatar
Another thing I was doing wrong at first was moving all the way back to the ACC position. It works for me in the on position and then one position rearward - not sure what that one is called. Of course AutoZone and Advanced Auto will read your codes for free.
Old Nov 4, 2007 | 07:36 PM
TedT's Avatar
I had the same problem. As Dale said, cycle between the position where the dash lights up and one click back.
Ted
Old Nov 4, 2007 | 07:43 PM
KMKDiesel's Avatar
Start with key in the off position. Hold one finger on the key release button so you can turn key all the way off. Use the other hand and turn the key all the way forward but dont crank the engine thats to far. Do this 3 times leaving on the 3rd time. You may have to set your park brake some have to some dont. It should pop up the code then ------ done.If done correct.
Totallyrad
Jul 19, 2011 07:41 AM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
