03 305 vs 04.5 325 Differences
Old Nov 1, 2007 | 10:30 AM
quick1300r's Avatar
Found on another site, all correct??
In developing the new “600,” Cummins and Dodge made numerous other improvements or changes to the engine:
• Air inlet redesigned to block hot engine air from entering, reducing the intake charge by 30 to 40 degrees.
• Intake resonator re-engineered for increased airflow
• Larger compressor on Holset turbocharger
• Engine cooling improved with new fan assembly and mounting fan shroud to engine for more efficient airflow through radiator
• Upgraded intercooler
• Upgraded exhaust valves
• Tailpipe increased to 4-inch diameter
• Improved sealing and gasket materials
• Oil-change intervals are now 15,000 miles (vs. 7,500 for competition).
• Holset turbocharger gets bigger compression side
• Switch to electronic control of wastegate
• Upgrades to exhaust manifold
• Revised intake ports in cylinder head
• New piston bowl geometry
• Different spray pattern from injectors
Old Nov 1, 2007 | 10:37 AM
ratlratl's Avatar
MMMmmmm.... Grits!!
Thumbs up A couple of things
In driving these new the 04.5 got less mileage, but had more pick up and quicker response when going from light throttle to half or full throttle. Electronic wastegate and different compressor were a big difference in stock configurations. But what fun is that? Most on here have not kept this anyway. Some later 04.5-05's got plastic ends on their i/coolers. Later switched back to metal.
Chris
Old Nov 1, 2007 | 10:46 AM
dodgezilla04's Avatar
catalytic convertor added to 600 models as well.
Old Nov 1, 2007 | 10:50 AM
kjp's Avatar
kjp
quick, where did you find this info, could you send links
Old Nov 1, 2007 | 11:21 AM
quick1300r's Avatar
here ya go
http://www.pickuptruck.com/html/2004...ive/page3.html
Old Nov 1, 2007 | 02:15 PM
kjp's Avatar
kjp
thanks much
Old Nov 4, 2007 | 12:42 AM
plessm's Avatar
Along with about 4 mpg less...
Old Nov 4, 2007 | 09:24 PM
Adaminak's Avatar
I remember reading about better exhaust valve seats, higher boost, and a third injection event. As far as mileage, my '99 got 18.7mpg over 34K miles, my '02 ETH/DTT got 19.4mpg over 28K miles, and my '04.5 has managed 18.8mpg over 46K miles, 99% of it at altitudes over 6000ft, and including a cross-country trip with a 5Klb trailer. I did notice the '04.5 got the worst pre-break in mileage of the three, averaging less than 12mpg prior to the cross-country trip.
Dirk5.9
Jan 12, 2011 02:45 PM
dezl-andy
Dec 11, 2010 05:20 PM
checkster
Oct 4, 2009 10:43 AM
ron717
Feb 18, 2004 10:44 PM
dodgeram
Jan 3, 2004 07:45 AM
