cam shaft sensor on 03
Old Mar 9, 2005 | 11:06 AM
gunracer1's Avatar
i have a friend of mine that is throwing up code po341. it is a 03 6 speed 4x4 and the dealer is jerking him around, wanting to keep his truck for a week. and he really cannot get by without it right now. it is throwing white smoke and getting 8 miles per gallon. anyone have any suggestions?
Old Mar 9, 2005 | 11:21 AM
justcampin's Avatar
Mine threw the same code yesterday..today it went off. No change in the way it ran
Old Mar 9, 2005 | 12:37 PM
bigblock2stroke's Avatar
There is something more wrong than the sensor. The fault is a rationality error. The ECM compares the readings from the crank sensor and cam sensor. If they are off more than a predetermined amount, the fault is thrown. Being that you don't have a fault relating to either sensor being open circuited or shorted to ground, something else is causing the problem.
I suppose it could be an intermittent short/open.
Check the tone wheel mounted on the balancer for missing/bent teeth.
The cam sensor is a "back-up" for the crank sensor, should something happen to the crank sensor/tone wheel.
Old Mar 9, 2005 | 07:55 PM
AK RAM's Avatar
It does sound like there may be something else going on there. The good news is if you want, you can replace the sensors for little of nothing and see what happens. I just picked up a new crank sensor for $36.00 from Cummins Northwest with overnight shipping. Parts are cheap compared to a couple days worth of downtime. I wouldn't try and get them from the dealer though....$$$
Old Mar 9, 2005 | 08:29 PM
metal_miner's Avatar
I had the same code generated 2 weeks ago, but I was running the TST box. The truck started and then died setting the CEL and then the code. I then restarted it no problem and later that day used a code reader to erase the code. Code never happened again. I agree with AK Ram - I would buy the sensor too and replace it myself (if it is bad) rather than have the dealer mess with it. The only thing with the camshaft sensor is that you have to be a contortionist to access and r/r it!
Hothead2500
Aug 1, 2010 09:39 PM
Det 1
17
Dec 22, 2009 08:32 AM
AH64ID
Jan 18, 2009 04:59 PM
Gabe32
16
Feb 22, 2007 06:37 PM
deezulsmoke
Sep 14, 2005 10:41 AM
