A/C help please
Old Jun 15, 2010 | 10:19 PM
jump's Avatar
A/C help please
Replacing the compressor. I don't know how much oil to pour in.
Old Jun 15, 2010 | 10:35 PM
BigIron70's Avatar
Cummins Guru
Drain all of the refrigerant oil from the old A/C compressor into a clean measured container.
Drain all of the refrigerant oil from the new A/C compressor into a clean measured container.
Refill the new A/C compressor with the same amount of refrigerant oil that was drained out of the old compressor. Use only clean refrigerant oil of the type recommended for the A/C compressor in the vehicle.
REFRIGERANT OIL LEVEL
When an A/C system is assembled at the factory, all components except the A/C compressor are refrigerant oil free. After the refrigerant system has been charged and operated, the refrigerant oil in the A/C compressor is dispersed throughout the refrigerant system. The accumulator, A/C evaporator, A/C condenser and the A/C compressor will each retain a significant amount of the needed refrigerant oil.
It is important to have the correct amount of refrigerant oil in the A/C system. This ensures proper lubrication of the A/C compressor. Too little oil will result in damage to the A/C compressor, while too much oil will reduce the cooling capacity of the A/C system and consequently result in higher discharge air temperatures.
CAUTION: The refrigerant oil in the R-134a A/C system is unique depending on the A/C compressor used. Use only PAG oils that are designed to work with R-134a refrigerant and the A/C compressor in the vehicle. Always refer to the A/C Underhood Specification Label for the correct oil designation. The oil container should be kept tightly capped until it is ready for use and then tightly capped after use to prevent contamination from dirt and moisture. Refrigerant oil will quickly absorb any moisture it comes in contact with, therefore, special effort must be used to keep all R-134a system components moisture-free. Moisture in the refrigerant oil is very difficult to remove and will cause a reliability problem with the A/C compressor.
NOTE: Most reclaim/recycling equipment will measure the lubricant being removed during recovery. This amount of lubricant should be added back into the system. Refer to the reclaim/recycling equipment manufacturers instructions.
It will not be necessary to check the oil level in the A/C compressor or to add oil, unless there has been an oil loss. An oil loss may occur due to a rupture or leak from a refrigerant line, a connector fitting, a component, or a component seal. If a leak occurs, add 30 milliliters (1 fluid ounce) of refrigerant oil to the refrigerant system after the repair has been made. Refrigerant oil loss will be evident at the leak point by the presence of a wet, shiny surface around the leak.
Refrigerant oil must be added when an A/C accumulator, A/C evaporator or A/C condenser is replaced. See the Refrigerant Oil Capacities chart.
Old Jun 15, 2010 | 10:44 PM
BigIron70's Avatar
Cummins Guru
diesel engine
A/C Accumulator 2 oz
A/C Condenser 1 oz
A/C Evaporator 2 oz
A/C Compressor Drain and measure the oil from the old compressor
jamesbfishin
Apr 16, 2016 11:32 AM
DHT
Apr 2, 2010 07:12 AM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
Lary Ellis (Top)
May 21, 2003 10:16 AM
