Buying a used common rail truck.
Old Jul 21, 2012 | 07:13 AM
BlueCuda's Avatar
Are most of the used trucks out there going to need injectors? I looked at a mint 05 with 115k that failed an "injector balance test" by a local reputable shop. He said most all of them likely need injectors unless there is an aftermarket filtration system on them.
I have also heard that the hanging rpms are a sign of failing injectors, is there much truth to this. I seem to remember the cr trucks all hanging to some extent. Thanks for any information.
Clark
Old Jul 21, 2012 | 08:52 AM
Pull Dog's Avatar
I've never heard the term "hanging rpms" could you please explain what that means.
My 05 had some injector issues when I bought it 4 years ago but the previous owner apparently ran cooking oil for fuel because it the exhaust system smelled like french fries. I had two injectors replaced and the problem continued. I used one bottle of Diesel Kleen and never had another issue. Great engine.
Old Jul 21, 2012 | 10:46 AM
roughstock's Avatar
I believe the extreme rpm hang/slow to drop is caused by bad injectors.
But is somewhat normal in CR trucks to keep u from barking the turbo.
And yes. I'm my experience, CR trucks wil need injectors around 170,000. Seen it at 115,000 and seen it at 200,000 mi.
Old Jul 23, 2012 | 06:26 PM
alltimelow1's Avatar
As a fellow 68 Cuda owner I wanted to reply to your post ... Any common rail, in my limited experience, with 150 - 200k is livin on borrowed time as far as injectors are concerned - I just got through replacing all 6 in mine and I will say that this is definately a job that you can tackle. mine now runs like brand new. I decided with 220k that I was going to rebuild the problem areas and keep driving her because it is the best truck I've ever owned... Money well spent :?)
I'll post some pics of my Cuda soon, hopefully you do the same :?)
hitcb1789
May 25, 2010 09:10 AM
Mike Holmen
May 21, 2008 10:23 AM
ddestruel
Jun 28, 2004 01:03 PM
