Brakes
Old Aug 15, 2005 | 12:26 PM
Kauaitransport's Avatar
Brakes
Searched 10 pages could not find what I need to do to replace pads and turn rotors on my O5 4wd front end. I have done 2wd never 4wd so I was wondering if there was a trick to getting the rotors off. Thank you for your help.
Old Aug 15, 2005 | 07:26 PM
underwoodtransp's Avatar
You can't get the rotors off without disassembling the whole hub assembly. It is a pain in the "you know what"!!! I would just replace the pads if the rotors aren't too bad. All you need to do is remove the two bolts holding the caliper on and pop it off. The pads will stay in the bracket and swap them out.. You will probably have to use a c-clamp to re-compress the pistons on the caliper use one of your old pads and loosen the bleeder screw when you start squeezing them.
wildcargo
Nov 29, 2005 04:20 AM
95black2615
Aug 22, 2005 09:21 AM
JImbo1
13
Apr 18, 2003 06:44 AM
