Brake and ABS light ON
Old Apr 22, 2009 | 08:03 PM
rubencumm3's Avatar
I have a 3500 dually and after I started to drive the truck off the lot the lights came on. Well, this was back in Jan. Didnt bother me much, cause my 97 did the same and I never fixed it. Put on a programmer and lights went off. I noticed that as long as I keep it under about 45 mph, lights stay off. When I get on the interstate lights come on. I think its the ABS sensor in the rear axle. Any opinion is welcome. Thanks
Old Apr 23, 2009 | 05:26 AM
1985cucv's Avatar
jack up each side on the front and check wheels for movement if there is you need hubs and good luck with that they can be a pain
Old Apr 23, 2009 | 07:28 AM
RAMRODD's Avatar
It can be just a sensor. I replace the front left on mine and took care of the light.
Old Apr 23, 2009 | 08:33 AM
04ctd's Avatar
there's a good thread somewhere.
most folks take of the sensors and clean them, clean mounting pad to bare clean metal, and it's GTG for a long time.
mine flickers every once ta while, but goes away before i get the energy to work on it.
Old Apr 23, 2009 | 09:42 AM
rubencumm3's Avatar
I know what you mean CUCV. I have done a hub in my old truck PITA!! Some one had told me it wat the sensor on the rear axle. About cleaning it, thats a good idea seeing the way the economy is, could save some money. Where did you see the thread ctd
Old Apr 23, 2009 | 08:26 PM
D45's Avatar
D45
When my truck's ABS/Brake Lights came on, I pulled the sensor out of each front hub and cleaned the grease off the sensor's tip.
I then re-applied a fresh coating of synthetic grease and reinstalled each sensor. The lights never came back on!
Old Apr 23, 2009 | 09:14 PM
1985cucv's Avatar
i will be greasing my bearings real soon like within 1000 miles
Old Apr 25, 2009 | 10:33 PM
wiskeyVI's Avatar
My ABS came on a couple months back while towing, and fit an uneven bridge junction.
Yesterday, I heard a "ding" from the dash, and my ABS & BRAKE lights came on. when It happened, it was in cruse, and the trk slowed, then kicked back in.
I used a Smarty JR to check for codes, and it showed an "INVALID SIM KEY" code.
It happend again, and no code showed, but the smarty said it cleared one.
Today, I disconnected all add ons, shut off the Pac Brake, and no cruz after it did it a few times.
I did not clear anything, as the last time I did, it came rightback, and wanted the dealer to see it when I take it in this week.
It ran fine with the ABS/BRAKE lights on, just heard a few "ding" every now and then.
After stopping for coffee, and hitting the road wioth a 100mi or so to go, the lights just went off....
Could all of this be due to dirty/bad ABS sensors on the front end??? Do the hubs have to come off to get at them?
I guess the rings can be cleaned while left on.
This would be great if that all that is causing this...50K on the trk and with some of the other things happening with it, my wife says "guess you'll be getting a differant truck now!"..
Old Apr 26, 2009 | 06:36 AM
fsixrider's Avatar
I had that problem driving thru Atlanta
pulling the 5th wheel. Ding...light came on. Still drove o.k.,stopped o.k. Took it to dealer, they replaced rear wheel speed sensor. O.k now.
Old Apr 26, 2009 | 07:44 AM
wiskeyVI's Avatar
So i guess that answers my own thoughts on switching to an older Dana rear end...just gotta put up with the lights.
this forum is truly great.
On Edit:
There is no ABS connection on the rear end. So I guess an old Dana would work.
Old Apr 26, 2009 | 07:24 PM
rubencumm3's Avatar
Thanks for all the input. I will take off the front sensors and clean them up good. I will also do the rear sensor that is in the center of the rear axle. See what that does to the lights. See, mine drives ok and stops ok also and I dont have annoying DING that is the reason I have not bothered with it, and well just dont have the time right now. Will have more time within the next couple of weeks. Will tell you all if it works just by cleaning them up.
Old Apr 27, 2009 | 07:48 AM
wiskeyVI's Avatar
The rear sensor in in the middle of the axel?
When mine came on the second time Sat., the speedo also went crazy....Then settled back to normal.
Old Apr 29, 2009 | 08:35 AM
wiskeyVI's Avatar
Well, we'll see. The dealer found the rear axel speed sensor was bad.
Not sure why this would effect the speedo the way it did.
So far so good.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
