Boxes, downloaders and auto trans pressure
Old Oct 26, 2006 | 04:10 AM
Dodgezilla's Avatar
Under normal driving conditions it is true. I can turn my TST on 9/9 and my truck will run fine if I'm just tooling around town without getting into it hard. The big problem occurs when you hook a trailer up behind that truck and it seems to tow it so easily when the boxes are turned up. It's towing it easily alright but all that torque is wreaking havoc on the trans...
Old Oct 26, 2006 | 08:26 AM
bluebull's Avatar
Originally Posted by raychem
If your refering to line pressure....no less throttle does not mean less pressure. Your VB has what is called Base Line Pressure...which means once the engine starts and the trans pump is running...it will supply that pressure period. Now if your low on at fluid you will see a drop in that pressure.
Richard
I'am not going to go into detail, leave that for the tranny wars. So that's why your pressures are around 65-75 psi at idle and the more you increase throttle the higher the line pressure becomes all the way up to around 150 psi or higher on modified transmissions. Your unmodified transmission does the same thing except the pressures are not as high as a modified one. the modified transmission also bring on the pressures faster.
t-boe
Jan 4, 2007 08:35 AM
Smokeman
Nov 16, 2006 10:33 PM
scottrod
Nov 2, 2006 04:20 PM
06er
Jul 22, 2006 12:13 PM
lightening ram
28
Dec 29, 2005 10:19 PM
