Boost pressure
Old Jan 10, 2010 | 03:27 PM
kylineman's Avatar
Boost pressure
My question is about Boost Pressure and weather.Should it take less boost to do the same work in colder temps?Just in case there is any confusion will these trucks build less or more boost in cold weather or will have no affect on the truck at all?
Old Jan 10, 2010 | 03:56 PM
Silverram03's Avatar
Generally colder air is more dense depending on humidity thus making it easier for the motor and turbo to work with cooler more dense air. So yes you would notice a slight difference in power with colder air, less boost pressure is required to do the same amount of work with higher boost pressure in warm air conditions.
Old Jan 10, 2010 | 04:04 PM
kylineman's Avatar
boost pressure
thats what I thought so if I am not seeing the high boost numbers doesnt mean I have a leak or anything is wrong just in cooler air the truck just needs less to do the same
Old Jan 10, 2010 | 09:22 PM
SpeedyWS6's Avatar
You shouldn't see much change in boost pressure from the weather changing. A change in altitude is a different story. My boost stays the same but my truck will not black smoke in the cold.
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
