Blown Starter fuse
Old Sep 16, 2007 | 08:24 AM
cuda's Avatar
Blown Starter fuse
Went to start my truck and nothing happened.., all the usual lites came on and the fuel pump ran.
Checked the fuse box and noticed the 30 amp fuse was blown, I swapped it out with wiper fuse which is also 30 amp.
Tried again and it blew again, had a guy pull start me (another dodge) to get it home.
I couldn't shut if off for fear of not starting it again, so I dropped it off at the local dodge dealer.
Could it be just the starter relay??
Truck only has 110000 km all highway use, minimal starts.
Is the starter covered under 115000 km power train warranty???
Any experiences or ideas much appreciated.
Thanks!
Old Sep 16, 2007 | 09:15 AM
jrussell's Avatar
Check the yellow wire down near the starter. There's a metal bracket it can wear against and ground out on causing issues like you describe.
Old Sep 16, 2007 | 09:45 AM
cuda's Avatar
will check it out, thanks!
Old Sep 16, 2007 | 01:26 PM
cuda's Avatar
Smile
It was a white wire to the solenoid that grounded out on a metal bracket. thanks for the info,...probably saved me a lot of money. Much appreciated!!!
Old Sep 17, 2007 | 06:37 AM
jrussell's Avatar
No problem man. Glad it was something so simple!
FMB
Nov 14, 2010 09:09 PM
Tractor Truck
Nov 11, 2005 08:57 PM
67HotRod
Sep 28, 2005 05:40 PM
Katrina
Jan 20, 2005 07:02 AM
DEC
Nov 6, 2003 06:48 PM
