Block heater install
Old Feb 21, 2008 | 11:48 PM
Townsend600's Avatar
I am told that my truck already has a block heater in it and all I need is a cord. Where is it located on third gen cummins engines. I'm ordering a cord from genos and need to know where to plug it in at on the block.
Old Feb 21, 2008 | 11:50 PM
_Adam_'s Avatar
The block heater is right by the oil filter. Pretty easy to do.
Old Feb 22, 2008 | 12:19 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
my 03 is in the same place, near oil filter housing by turbo. It came with a cord ready to plug in and my friend has a 07 without a cord. We just took it out and made up a cord to attach to his. nothin special.
Old Feb 22, 2008 | 07:03 PM
icrider's Avatar
remove your intake tube that goes from your airfilter to your turbo...you'll be able to get to it easier. It being your block and where you plug the cord into the block. use the search feature, I'm sure someone has posted photos.
the cord comes with three 'plugs' on it...these go into the frame at specific points to help route the cord the correct way and to then hold it in place...
It's quite easy considering the plugs on the cord go into pre-drilled holes on the frame...that way you know you're routing it correctly.
Old Feb 23, 2008 | 10:52 PM
RADICALRAY's Avatar
i payed 5 dollars and 30 cents for my cord local auto parts store carry them
radicalray
Old Feb 24, 2008 | 10:33 AM
Danavilla's Avatar
Heater cord location:
Old Feb 24, 2008 | 11:04 AM
Pooter's Avatar
Yep, your truck already has the heater plug in the block, you just need the cord.
I bought mine from Genos when I ordered some oil filters/fuel filters...
Also too, its REALLY easy to install while youre doing a oil change and have the filter off, otherwise its a little tight to get your hands in there, or it was for me anyway...
Old Feb 24, 2008 | 11:07 AM
icrider's Avatar
5 dollars and 30 cents....grrrrrrrrrrrrrrrr...not to get on the 'I hate the dealer' band wagon, but they want $67 for it...punks!!!!!!!!!
nice call on installing during an oil change...that'd be a smooth move.
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
Reelay
Dec 1, 2005 06:14 PM
