Blankety Blank High Pressure Lines????
Old Feb 27, 2011 | 11:43 AM
mtblackdog's Avatar
So I just blew my third high pressure line into my injectors. They keep cracking and stranding me. The dealer says that he goes through a dozen a month. I wont even get into the "should be a recall thought". My question is, does anybody make a flexible line that i could keep in the truck so Im not stuck on the road again. 2005 1 ton.
Old Feb 27, 2011 | 12:09 PM
BigIron70's Avatar
Cummins Guru
I don't think there is a flexible line that could withstand that much fuel pressure. Make sure all the bolts are tight on the brackets. Replaced 3 lines on the same injector? New lines are supposed to be thicker wall to prevent cracking. Make yourself a cap off tool from old injector line. Cap leaking injector line at rail will get you home with one dead injector. I have done this many times to get a no start off the road and back to the shop. Fuel rail cap off tool.
http://www.handsontools.com/Miller-T...-_p_36443.html
Old Feb 28, 2011 | 11:20 PM
ramman's Avatar
Big Iron70 what exactly did you use to make the cap,sounds like a good item to have in the dash pocket,espically if I can make it CHEAP. Thanks
Old Mar 1, 2011 | 09:54 PM
homewrecker's Avatar
cut the line, pinch it and weld it or buy this......
http://www.genosgarage.com/prodinfo....mber=LT-TESTCA
VikingDiesel
36
Nov 23, 2006 10:04 AM
04ctd
Nov 4, 2006 09:14 AM
fishin fever
Apr 24, 2006 02:45 PM
hotdram
Aug 31, 2005 09:32 AM
mitchkim
20
Jan 16, 2005 08:47 PM
