BHAF change interval
Old Mar 25, 2005 | 10:19 AM
JohnnyH's Avatar
I know it all depends on driving conditions, but I pretty much drive on paved roads all the time. I installed the Donaldson BHAF and have an outerwears cover on it. I didn't reuse the filter minder. What kind of mileage can I expect out of this thing. I was going to replace the stock one every 15000 miles. The BHAF costs a little more than double the stocker, so I hope to get at least twice the life out of it.
Any thoughts....
Thanks
Old Mar 25, 2005 | 05:11 PM
phox_mulder's Avatar
I've heard of 50K plus out of a BHAF with a prefilter.
phox
Old Mar 25, 2005 | 07:52 PM
Dodgezilla's Avatar
If you have an air compressor you can just blow most of the dirt off of the filter and reuse it......
Old Mar 26, 2005 | 09:13 AM
05mxdiesel's Avatar
how did u guys attach your air/temp sesnor when you went to the BHAF. I purchased the NApa #2790 and I want to make sure everything is correctly done.
Old Mar 26, 2005 | 09:15 AM
herb's Avatar
i called mfg. and they said to blow out loose debrie wash with Dawn dish soap let dry spray with a light coat of wd-40
Old Mar 26, 2005 | 09:54 AM
JohnnyH's Avatar
I didnt. It is zip tied to the top elbow for now. I am working on a better solution.
Old Mar 27, 2005 | 04:10 AM
Marine's Avatar
Veteran: Marine Corp
You will be able to go at least 35,000 miles without a prefilter. I have done it.
Mike
dieselnewbie
Oct 14, 2004 10:26 PM
Mark Hodowanec
Sep 17, 2004 07:25 AM
FOXY005
38
May 19, 2004 04:02 PM
ICEBOX
Jan 20, 2003 05:16 PM
