Bent axle or bad ball joints?????
Old Jan 16, 2012 | 10:02 PM
YounanDiesel's Avatar
Bought another 2006 Ram 2500 4x4 with 350k miles on it, completely stock. The only problem is that the front wheels are slanted upwards (top of the tires are slanted towards the motor). Therese so absolutely no play when I jack up the front end and try to wiggle the tire front back side to side. Can it be that the ends of the front axle are bent ( maybe the truck was driven off a ramp ) or bad ball joints jammed in that position??. Is it even possible to bend the axle to were the where the tires are slanted up? Will replacing the ball joints help or is there something else that Im missing...
Thanks
Old Jan 16, 2012 | 10:58 PM
anyone???
Old Jan 17, 2012 | 06:26 AM
Steve-l's Avatar
First, if it is a 4x4 (4 wheel drive), I see no way what you say is possible because the vertical wheel position is controlled by the yoke (the part that contains the ball joints) and that is welded to the axle housing. However, if it is a 2 wheel drive and you have a lift kit, it is possible if the lift kit was installed incomplete or incorrectly, as the geometry of the front suspension has been drastically altered.
Old Jan 17, 2012 | 07:44 AM
BigIron70's Avatar
Cummins Guru
I have seen front axle tubes bend and cause that problem. Usually the axle seal will start leaking on that side also. Housing will need to be replaced if that is the problem.
Old Jan 17, 2012 | 09:24 AM
.boB's Avatar
Adjusting camber is not easy, but is possible. It's not cheap, either, but maybe cheaper than a new axle.
At 350K miles, probably needs new ball joints anyway.
http://www.northstarmfg.com/userfile...ins(17698).pdf
Old Jan 17, 2012 | 11:32 AM
Hintonc393's Avatar
Someone may have installed adjustable ball joints, hard to tell with out taking it all apart. On the normal ball joints the shaft will be perfectly straight the adjustable ones will have a offset. If the axle tube is bent you may be able to adjust some of it out with adjustable ball joints but the axle seals will never hold up.
Old Jan 17, 2012 | 12:32 PM
It is a 4x4 completely stock. Yeah the seals at either end do leak oil. How is it possible to bend the axle housing with stock wheels and on road driving. If it was a rock crawler I'd understand haha, I think I'm going to replace the ball joints and see if it helps. I'll keep you guys posted. Cheers.
Old Jan 17, 2012 | 12:46 PM
jhenson's Avatar
Has me curious as well....surely with the tires going the direction you say, the inside treads should be wearing badly!!! My inside treads started wearing funny and the truck would wander on the road but I didn't have any major movement in the wheel with the tire off the ground. Did balljoints and updated steering system and it drives like a new truck now.
Hopefully balljoints are your only problem.
Old Jan 17, 2012 | 12:53 PM
Dr.Dizzle's Avatar
Given that you mention the leaking axle seals, there is a good chance the axle tube is bent/damaged.
Old Jan 17, 2012 | 07:33 PM
Texan1983's Avatar
if the truck went off the road and jumped a ditch it would bend the axle tubes for sure, seen that happen. even on stock trucks.
Old Jan 19, 2012 | 08:50 PM
BLACKBEAR's Avatar
steve-1 I think you are right it has a 6in lift kit.
Old Jan 19, 2012 | 11:16 PM
This isnt the truck in my signature, its another truck I picked up last week. Im taking it apart this weekend. Ill keep you guys posted on what I figure out. Ill try to get pictures also. Cheers..
Busboy
Nov 7, 2012 11:53 AM
firebill1720
20
Mar 5, 2010 09:23 AM
Wulzcat
Dec 19, 2009 05:15 PM
getblown5.9
May 2, 2006 10:01 PM
