Belt Squeak only when cold
Old Jun 1, 2012 | 12:06 PM
maddog1927's Avatar
My fan belt started squeaking, only on initial start up, in the morning, or if I leave it parked for long enough for the engine to cool down.
I have 120K on the ticker, and have never changed the belt, seems like a good place to start. Anything else I ought to know about? Is this typical of any one accessory on it's way out?
Old Jun 2, 2012 | 07:39 AM
DodgeRam24V's Avatar
spend the big bucks, get a good one
Old Jun 2, 2012 | 07:12 PM
maddog1927's Avatar
$50 napa belt, all is good. no more squeak.
Old Jun 3, 2012 | 07:31 AM
i was having a fraying on the edge of my belt problem, couldn't figure out why? keep looking for a bolt or something that it was rubbing on.
finally one day taking a real close look at it, i discovered i have 8 ribs on all my pulleys except the alternator, it had 7.
the alt went bad and i bought a new one at the local parts store and didn't realise the difference. i have a new belt under the seat with the new pulley they gave me.
my Gates belt still works fine with 7 ribs, I'll change them someday.
Old Jun 3, 2012 | 08:37 AM
wellmax's Avatar
spray some water on the belt using a spray bottle when its making the noise, if the noise goes away you need a new gates gator back belt.
if the noise does not go away then you probably have a bad bearing.
Old Jun 3, 2012 | 09:18 AM
maddog said:
"$50 napa belt, all is good. no more squeak."
he got the good stuff!
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
ytodd
Nov 2, 2007 09:57 AM
gman07
May 9, 2007 06:03 AM
hotdram
31
Sep 17, 2005 08:00 AM
