Bed Rails
Old Apr 27, 2006 | 01:00 PM
jrogers's Avatar
Bed Rails
I just got a line x liner sprayed in my truck. The line x guy said that Dodges have weak bed rails and that I should spray over the rail.....I told him it didn't matter cause I had diamond plate bed caps on the way.....Anyone else have troble with weak bed caps.
Old Apr 27, 2006 | 01:22 PM
TRC51's Avatar
PSsshhtt.. please. Is he saying that Linex will make them more rigid? They charge more for "over the rail" that's all he was doing. I will tell you this, they are a heck of a lot stronger than my last four Chevys. The Chevy would dent if you just put your knee on the rail to go over the side of the bed! If you are putting bed rail caps on anyway, don't bother.
Sevir's Avatar
most trucks now-a-days have weak bedrails. I line-x my over them and they added a good bit of strength. With todays auto companys cutting every penny they can, we get crappy sheet metal. I know my '79 chevy i can stand on my hood and it not even bend, when i wash the roof of my dodge its just bends and warps with the slightest of pressure.
Old Apr 27, 2006 | 01:23 PM
SOhappy's Avatar
I had mine sprayed, not because they are "weak" (I walk on mine all the time, weigh about 220lbs., not much flex if any), but just because truck bed rails in general take a beating. More for cosmetic reasons than structural. Spraying won't "strengthen" the rail per se, it just protects it from small dents, dings and scratches. Diamond plate would certainly stiffen them up though.
Old Apr 29, 2006 | 03:24 PM
Equalizer 2's Avatar
Like jwooden I did mine because I like the way it looks and I walk on them frequently. Also they do take a beating and Line-X does protect them. I haven't noticed any flex but haven't looked for any either. I didn't check the pricing on rail caps I just had them sprayed. I do have a diamond plate box in the bed and I find that in the summer sun that the Line-X is not as hot as the diamond plate.
Old Apr 29, 2006 | 08:44 PM
HYRIDEJEEP's Avatar
I bought bed raiils. They were on my truck for about a week & I was washing my truck & noticed that they had scratched the living hell out of my truck bed . I went back to the place I bought them from & they took them off & buffed the scratches out. Then they went ahead & put rhino over the rails for free.So If I was you i'd send them back!!!!!!!!
Old Apr 29, 2006 | 10:23 PM
sumner's Avatar
Thumbs up
I layed the bed caps on and drew a line. Had bullhide spray to that line. So in essence, i had them sprayed and have the caps. You cant see the spray underneath. The reason i did it that way was so when the caps vibrate, they wont scratch the truck and provide a starting place for rust...
Old Apr 30, 2006 | 11:07 AM
Jeff in TD's Avatar
I pretty much went with the same theory.
When I had mine sprayed, I had them stop on the outside edge of the top of the rail, not wrapped down the sides slightly like they usually do.
I didn't want bed rail caps, but would get some if I dented up the bedrails someday. This way if I put on caps, the liner won't show on the outside edge of the caps.
WheelingCJ5
Dec 12, 2006 05:21 PM
Patrick Campbell
Oct 31, 2006 05:14 PM
PapaPerk
Sep 1, 2005 01:06 PM
Pineapple Kid
Feb 12, 2005 09:14 PM
Fummins
16
Oct 31, 2003 08:31 PM
