ball joint tools
Old Mar 16, 2015 | 05:36 PM
sljim's Avatar
ball joint tools
anyone know the part numbers for the ball joint press adapters , otc or other brands
Old Mar 16, 2015 | 10:05 PM
cLAYH's Avatar
OTC 6530
About $500-$600 from NAPA for the complete set. Has a bunch of stuff you probably won't use.
This Princess Auto kit will get you part way there, then find some thick wall pipe with the right ID and make up your own adapters.
Ball Joint Service Kit | Princess Auto
A big hammer and a good heavy punch/dowel work well for pounding them out.
Old Mar 21, 2015 | 09:54 AM
Steve-l's Avatar
No special tools required. In fact those "special tools" often cause damage. Tapered joints, ball joints, bar ends, whatever is best removed using two LARGE hammers. One as a backing and the other used to strike the element with the tapered hole. This shock will distort the tapered hole and the male element will just pop out, no strain, no pain and no damage. Try it, you'll like it!
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
CRSmith
15
Nov 24, 2005 11:38 AM
