Ball joint ROCKAUTO
Old Dec 6, 2008 | 03:14 AM
MiB's Avatar
MiB
Ball joint ROCKAUTO
I have a bad upper ball joint, which part do i need?
4 wd
2004 DODGE RAM 2500 PICKUP 5.9L 359cid L6 DIESEL FI Turbo (6) : Suspension : Ball Joint Related Parts
Item Price Core Total
MOOG Part # K7465
Front Suspension; Lower; 2WD
$30.79 $0.00 $30.79
SPICER Part # 5051311 {Professional Grade}
Front Suspension; Lower; Four Wheel Drive (4X4); Solid Front Axle
$56.79 $0.00 $56.79
SPICER Part # 5001117 {Professional Grade}
Front Suspension; Upper; Four Wheel Drive (4X4); Solid Front Axle
$85.79 $0.00 $85.79
SPICER Part # 6154007 {Professional Grade}
Front Suspension; Upper; Four Wheel Drive (4X4); Plus Or Minus 1/2 Degree Camber; Offset Ball Joint Replaces OEM To Provide 1/2 Degrees Positive(+) Or Negative(-) Camber/Caster Change
$88.79 $0.00 $88.79
SPICER Part # 6154008 {Professional Grade}
Front Suspension; Upper; Four Wheel Drive (4X4); Plus Or Minus 1 Degree Camber; Offset Ball Joint Replaces OEM To Provide 1 Degree Positive(+) Or Negative(-) Camber/Caster Change
$88.79 $0.00 $88.79
SPICER Part # 6154009 {Professional Grade}
Front Suspension; Upper; Four Wheel Drive (4X4); Plus Or Minus 1-1/2 Degree Camber; Offset Ball Joint Replaces OEM To Provide 1-1/2 Degree Positive(+) Or Negative(-) Camber/Caster Change
$88.79 $0.00 $88.79
MOOG Part # K7448
Front Suspension; Upper; 4WD; w/4500 lb. Dana 60 Axle; adjustable ball joint; allows up to 1 Deg. adjustment of camber and caster
$98.79 $0.00 $98.79
ACDELCO Part # 45D0117 {#19142502}
Front Upper Control Arm Ball Joint; SOLID FRT AXLE; w/4WD
- Stocked in outlying warehouse--shipping delayed up to 1 business day
$80.79 $0.00 $80.79
ACDELCO Part # 45K16009 {#19136553}
Front Upper Control Arm Ball Joint; OFFSET BALL JOINT REPL OEM TO PROVIDE 1-1/2 DEGREE (+) OR (-) CAMBER/CASTER CHANGE; w/4WD
$132.99 $0.00 $132.99
ACDELCO Part # 45K16007 {#19136551}
Front Upper Control Arm Ball Joint; OFFSET BALL JOINT REPL OEM TO PROVIDE 1/2 DEGREES (+) OR (-) CAMBER/CASTER CHANGE; w/4WD
ACDELCO Part # 45K16008 {#19136552}
Front Upper Control Arm Ball Joint; OFFSET BALL JOINT REPL OEM TO PROVIDE 1 DEGREE (+) OR (-) CAMBER/CASTER CHANGE; w/4WD
Old Dec 8, 2008 | 10:26 AM
MiB's Avatar
MiB
some one else maybe have an other suggestion on a ball joint
Old Dec 8, 2008 | 11:07 AM
bradler's Avatar
I'm looking at replacing uppers and lowers right now too and Carli has an extreme duty upper that is by far the best quality upper ball joint you can get. Just can't decide if it is worth $500, but it is a "life of the truck" part. My truck goes through OEM uppers in 30k or so and i'm sick of replacing them. Noticed you listed several BJ's with the offset. Not sure with your 4.5˝ fabtech, but i've heard you don't need the offsets if everything alignes and handles well with your current set up.
Crossy's son
Jul 19, 2012 11:02 AM
MARF75
Aug 21, 2010 02:31 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
