Ball Joint help....
Old Mar 4, 2007 | 08:54 AM
  #31
doug60's Avatar
Moog fine print
Originally Posted by ollie32
Just replaced mine with the MOOG adjustable, top and bottom at 107km Lifttime warrentty on Moogs parts. Dealership told me to pound salt, 3 years or 60,000 they are covered.
This truck was the last $cent chrysler will ever see out of me, EVER!
FYI Moogs Lifetime replacement is actually a one time free replacement . I am on my fourth track bar on my 96 .
Moog would not warranty a second time.
Old Mar 4, 2007 | 09:10 AM
  #32
dbossdiesel's Avatar
Well, this Sat, I'm replacing all 4 ball joints and all my u joints are junk and dryed out! EVERYTHING is being replaced with geasable parts!
Old Apr 17, 2007 | 04:37 PM
  #33
Crabjoe's Avatar
Guys, how hard is it to replace ball joints? I'm thinking about doing this being that my truck pulls to the left even though the alignment is dead on and I have 90K miles on my truck. Shoot, I might as well replace the track bar too, now that I think about it.
BTW, anyone know where I can get the best price on Ball Joints and a new trackbar?
Old Apr 17, 2007 | 08:57 PM
  #34
2500's Avatar
absolutely amazing!!!!
everyone moaning about ball joint failure.... I've posted solution of injecting grease into ball joints designed without grease zerts. this is done with a large hollow needle grease fitting. poke needle through rubber boot at base. inject full of grease.
it's not rocket science, keep your ball joints from going dry, if you want decent service life.
NOT A SINGLE PERSON HAS MADE A COMMENT!
Old Apr 17, 2007 | 09:22 PM
  #35
brickenbone's Avatar
Dodge front end design is JUNK
Old Apr 18, 2007 | 04:09 PM
  #36
SBishop's Avatar
2500
Most people don't like to admit to a good idea when they see one
Old Apr 18, 2007 | 06:27 PM
  #37
2500's Avatar
can't believe my eyes...
someone actually acknowledge my posts
seriously ... I've been injecting grease into joints without zerts for a number years. I've never had a ball joint or tie rod end or Ujoint failure when it's been pumped full of grease.
Originally Posted by SBishop
2500
Old Apr 18, 2007 | 06:28 PM
  #38
Highway 4x4's Avatar
I did inject mine before they went bad, 50k miles and running. I think it turns easier and I get better MPG. Just kidding, I did fill the boots with the needle, I figure there is nothing to loose and it should help.
Old Apr 18, 2007 | 06:34 PM
  #39
nfsommer's Avatar
can you guys post a pic of where you inject?
Old Apr 18, 2007 | 07:53 PM
  #40
wreedCTD's Avatar
in my arm. j/k i would like to know also.
Old Apr 18, 2007 | 09:40 PM
  #41
2500's Avatar
you can puncture rubber boot most anywhere. then fill with grease. but it's better near base, so when you pull needle out it somewhat seals. but if a little grease pukes back out. not a big deal.
NOTE: this needs to be done while joints are still good. once joint goes dry, damage starts and will not heal itself. even if you fill back up full of grease. it's too late.
long ago.... when full service gas stations were all over. it was normal to take your vehicles in for an oil change. shooting grease zerts in tie rod ends, ball joints, Ujoints etc was serviced along with oil filter. this was normally done every 3000-6000 miles.
car mfg have purposefully left off zerts to make sure major components don't last forever. usually they last over 100K or beyond mfg's warranty period.
Old Apr 18, 2007 | 09:46 PM
  #42
Crabjoe's Avatar
Does anyone know if MOOG part # 7448 is the correct part for the 3G 4x4 Rams? I'm asking because I'm getting ready to order but the description says it's for a DANA 60.
Can anyone confirm the correct Moog Upper Ball Joint part number?
Thanks!
Old Apr 18, 2007 | 10:18 PM
  #43
caltom's Avatar
Crabjoe,
Uppers K7448
Lowers K7467
Old Apr 19, 2007 | 07:29 AM
  #44
Peterbilt's Avatar
Specs are .060 for uppers and .090 for lowers. Correct procedure is to use a dial indicator. Seems like 1/8" is too much.
Pete
Old Jun 22, 2007 | 09:23 PM
  #45
Willard1's Avatar
I have the same problem. BALL JOINTS, second time with less that 100,000.
This time the tie rod and the wheel berrings as well. Dealer no help. Not impressed. My last diesel was a 4X4 and another brand. 264,000 and no front end repairs. This truck is abused and the maintainance is on the dealer plan. NOT inpressed with it a 2003 3500 duelly 2X4 and in the last 16 months, cracked injector, turbo replaced, lift pump replaced, and each time down for 7 to 10 days waiting for parts.
