bad u-joint...already?
Old Feb 21, 2008 | 10:25 PM
one54ton's Avatar
noticed last weekend my truck had a funny vibration and noise and a bit of a clunk. we put it up on a lift at the local tire shop. turns out the bushing on the rear u joint were fairly worn the driveshaft had tons of play. just took it to the dealer for warranty. is the common on 3rd gens? my 200o had near 600 rwhp and i never had a problem. wierd
Old Feb 21, 2008 | 10:32 PM
coyle2285's Avatar
on my 05 ive replaced them twice and barely have 80 thousand on the truck.
Old Feb 21, 2008 | 10:36 PM
OOPS's Avatar
Did you correct the d-shaft angles when you put the lift on?
Old Feb 21, 2008 | 10:44 PM
rjm022's Avatar
replaced mine at 60,000 miles with spicers. been fine since.
Old Feb 21, 2008 | 10:53 PM
homewrecker's Avatar
Replaces mine with Spicers as well.Only 40k on the factory u-joints.
Old Feb 21, 2008 | 11:11 PM
torquefan's Avatar
On the 3rd gen trucks, they changed from the dependable non-greasable Spicers to AAM joints. They don't last nearly as long. Replace them with 2nd gen style Spicer joints and you won't have to worry again.
Old Feb 21, 2008 | 11:13 PM
busa's Avatar
Have replaced a handfull on 3rd gen's at the shop, all rear shaft, rear joint, maybe a weak part from Dodge???
Old Feb 21, 2008 | 11:27 PM
RAMRODD's Avatar
From my experiance the rear joint is always the first to go. I just replaced mine with 43,000. I put on a Precision U-joint, guess I will see if they are any good.
moparonly
Aug 17, 2013 03:32 AM
irocpractice
Sep 16, 2009 05:46 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
