Bad left front rotors
Old Jun 25, 2007 | 02:49 PM
shaft's Avatar
Question Bad left front rotors
My truck's odometer just rolled to 50K and in need of a brake job. I noticed the left front rotor is in really bad shape (deep groves but only about half of the outer part of the disc) compared to the right front rotor. I'm not sure why this is happening. Anybody encountered this before? What would cause this to occur? How can I prevent this from happening again? Any input or advice is greatly appreciated.
Thank you.
BYW, when I hit the brake, I can hear the left front brake making this hissing, clamping noise (not squeaking). I'm not sure if this means anything.
Old Jun 25, 2007 | 07:19 PM
raycarlson's Avatar
make sure and rebuild your calibers when you do new pads and rotor,your two bolts that the caliber slide on probably dried out(no lube)and or piston bore is shot,you probably have no lining left on your pads and your grinding metal to metal when you apply brakes
04ctd
Aug 3, 2007 04:19 AM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
Madoco
Aug 13, 2003 09:42 PM
