Axle Size?
I think they are asking you whether your truck has a Hemi or Cummins. I have never heard anyone ask about axle tube diameter when spec'ing a lift, but I can understand why. The hemi srw's have 10.5 rear axles. The Cummins has an 11.5" rear axle (4" axle tube).
I know you have the Cummins...it says so in your signature.
My point was that most lift kits for our trucks are sold based on whether you have a diesel or gas motor. The springs on the front are different to handle the weight variation and the rear lift is based on which axle you have for U bolts, lift blocks, etc.
Most 4WD stores will just ask you "Diesel or Gas?", not "3.5" or 4"?.
Your best bet is to go to the website of the lift manufacturer you are interested in. Their sites are pretty detailed and you will be able to get the part #'s you need so that you can verify that the retailer you are working with is getting you the right stuff.
. My point was that most lift kits for our trucks are sold based on whether you have a diesel or gas motor. The springs on the front are different to handle the weight variation and the rear lift is based on which axle you have for U bolts, lift blocks, etc.
stealman1
May 6, 2008 08:05 AM
ridofpwrstroke
Aug 25, 2006 05:24 PM
MX429
Aug 20, 2006 06:41 PM
04ctd
Apr 5, 2005 11:59 AM
