axle seals and ball joints
Old Aug 12, 2010 | 01:25 AM
partisan1911's Avatar
My front passenger side axle seal is leaking pretty good now. I figure if I have to pull the front end apart I might as well do the ball joints so I don't have to dig into it again for a while. Does anyone know who has dynatrac or carli ball joints in stock for an '05 4wd?
Old Aug 12, 2010 | 10:48 AM
storx's Avatar
i just use the ones at advance... lifetime warranty.. and been working like a charm ever since.. i think they were $25 a peace
Old Aug 12, 2010 | 05:13 PM
bradler's Avatar
go straight to the source both dyna track and carli sell direct. bummer about the axle seals not that many problems with them yet. the seal actually grips the axle shaft and has a bushing where the seal rotates inside itself if that makes sense. they are a pita to install though gotta pull the diff all out and drive em in from inside diff housing. i would also do axle u joints so you don't have to pull axle shafts out later as re-installing them is when most seals get chundered.
firebill1720
20
Mar 5, 2010 09:23 AM
Wulzcat
Dec 19, 2009 05:15 PM
getblown5.9
May 2, 2006 10:01 PM
Dynocon
Mar 5, 2005 06:24 PM
