Automatic Transmission Won't Downshift When Stopped
Old Mar 6, 2010 | 04:38 PM
Mudinyeri's Avatar
I've been having all kinds of problems with my truck (in sig) lately. Flexplate bolts stripped, a piece of the plate broke off and took out the torque converter. Dealer replaced the flexplate and torque converter. Front pinion bearing failed, broke into pieces and took out the front differential.
Anyway ... I towed for the first time today after having the front differential fixed and noticed when I stopped at a stop light that it seemed like the transmission didn't downshift into first when I stopped. I was stopped for several seconds. It seemed like I was taking off in second gear. At the next light, I manually shifted down to first and then back up to drive before taking off. Power and gearing seemed normal.
Any thoughts?
Old Mar 7, 2010 | 02:48 AM
Spooler's Avatar
Sounds like you have a bad governer pressure solenoid and transducer. Get that changed and you should be good.
Old Mar 7, 2010 | 06:24 AM
gpshemi's Avatar
I had something goofy like this happening with mine. Wouldn't shift out of gear when coming to a stop and would stall out the truck. Ran like hell. Turned out to be an abs wheel sensor had water in the plug. Supposedly it tells the trans how fast yer going and alters gears based on that. IDK.
Good Luck
freightrain
26
Feb 13, 2012 07:12 PM
blwnsmke
Jul 10, 2008 02:32 PM
MaineDiesel
Sep 28, 2007 04:20 PM
Buz
Aug 22, 2007 05:29 PM
ssigmon
Mar 17, 2006 08:31 AM
