Auto trans question...Any ideas?
Old Feb 25, 2008 | 11:00 AM
josberg's Avatar
My auto trans starts by jumping not completely out of over drive, but it increases RPM by 150-200 when it occurs. Eventually it gets bad enough where it completely jumps out of overdrive. It is presently at a dealer, and they can find nothing (no codes). Seems to be worse in colder temps (20-25 deg F) outside. Any ideas??
Old Feb 25, 2008 | 11:02 AM
HOV's Avatar
HOV
What?
Can you describe what's happening more clearly?
Old Feb 25, 2008 | 11:19 AM
josberg's Avatar
When driving down the highway 55-70 mph, truck RPM's will jump 150-200 RPM higher (seems to be downshifting, but not completely out of overdrive if that makes sense). Truck would fail on upgrades, downgrades, flat road, did not make a difference.
Over time, (approx 15 miles of driving) this gets more frequent, until truck completely downshifts out of over drive. But if you let off the accelerator, it will go back in O/D but will fail again.
Dealer has replaced throttle position sensor, but truck continues to act up. They have just recently put in the lift pump upgrade (pump in tank as apposed to mounted on block) and they say that this has cured the problem. Low fuel press was the only code they were getting.
They have to continued to drive it the past few days, and can not get the problem to return.
My question is, could this have been a fuel problem? I never noticed a loss of power. Just seemed like a trans issue the whole time.
Hope this is specific enough. Thanks for reading
Old Feb 25, 2008 | 11:24 AM
HOV's Avatar
HOV
Sounds like your torque convertor is unlocking, then the trans is downshifting.
Generally this will happen if there's increased load. Was it happening while towing? On hills? In extreme wind conditions?
Old Feb 25, 2008 | 11:27 AM
josberg's Avatar
No not at all. Just driving empty truck down the highway. It would happen equally on hills, flat ground, and downgrades.
Old Feb 25, 2008 | 03:40 PM
j-fox's Avatar
We could help alittle more if we knew what year your truck is.
Fill out the profile, please.
Next time it does it, turn off overdrive, to see if it is od instead of the converter clutch.
BTW if it shows no codes, some dealers are lost!!!!!!!! Poorly trained.
Old Feb 25, 2008 | 08:55 PM
josberg's Avatar
Sorry, 2003 2500 4x4.
Old Feb 25, 2008 | 11:29 PM
Dieselnick's Avatar
Mine did the same thing when it was new. Turned out to be some sensor in the trans.
Nick
smokeum99ta
Mar 31, 2008 04:18 AM
Conn
Nov 26, 2007 04:21 PM
Dufrain
Apr 5, 2005 09:00 PM
