auto shift questions when towing
Old Oct 24, 2009 | 11:39 AM
darkvader's Avatar
Truck in sig with 3 axel 15000# tag trailer(enclosed toy hauler). 23k gross, in tow haul. When down shifting under load it will shift to 3k rpm then quickley shift down 500 rpm. When upshifting it wants to hang(ie. if you want 65mph you have to over shoot to 68 or so the let off to shift up.). This is all at 55 to 70 mph rolling hills and sligth grades. Is this normal.
Clark
Old Oct 24, 2009 | 12:26 PM
torquefan's Avatar
Sounds normal to me. When you downshift, it will start by unlocking the torque converter. The RPM will increase slightly. Then it will downshift a gear. The RPM will make a big jump up. Then the converter will lock up again and the RPM will drop by 500. The same is occuring when you upshift. Pulling a heavy load it is much more noticeable than without, because the duration of the shifts will be longer- your foot is on the throttle harder and the transmission is trying to stay unlocked longer.
Old Oct 24, 2009 | 12:35 PM
darkvader's Avatar
Thanks. I am kinda new to autos(how new can you be at 66) and it just seemed a little busy.
Clark
Old Oct 24, 2009 | 06:24 PM
torquefan's Avatar
You're welcome. I haven't owned too many autos either.
Old Oct 24, 2009 | 07:30 PM
Spooler's Avatar
That's normal with 3.73 gears towing heavy. That is why folks with auto's get 4.10 gears that tow heavy.
Dave7060
0
Feb 13, 2012 05:03 PM
97CTD
Jul 29, 2007 08:22 AM
poogan
May 4, 2007 08:47 PM
Ilikebikes
Oct 11, 2006 07:56 PM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
