Argh!! Front shock install problem!
Old May 2, 2017 | 10:34 PM
HorseHauler's Avatar
Hey everyone, so I went to install some new bilstein shocks today, drivers side front went great, went to do the passenger side and the dang nut on the bottom bolt broke free and now it just spins. Anyone else had that problem? I can't fit a wrench in there to hold the nut. Any ideas on what to do?
Old May 3, 2017 | 03:18 AM
ofcmarc's Avatar
Try taking the upper shock mount off the shock then jack the axle down and remove the spring. Might get enough room to get at the nut with the spring out of the way.
Old May 3, 2017 | 08:48 AM
johnh's Avatar
hire a mechanic
Old May 17, 2017 | 06:20 PM
Hawglip's Avatar
Sawsall the shock in half.
Old Dec 15, 2018 | 12:24 PM
surfram's Avatar
I fed the appropriate size wrench from the top inside the coil spring to hold the nut. Took a few tries but it worked.
Old Dec 16, 2018 | 07:08 AM
Pull Dog's Avatar
Just take a grinder and grind the nut off. I just went out and looked at my 05 2WD and it would be easy to do!! You may also take a hack saw and cut the nut down the side until you can take a chisel and remove it. This should not be too hard.
freight train
22
Mar 25, 2013 04:46 PM
stumpjumper
Aug 21, 2007 07:14 AM
2500CTD
Oct 5, 2005 06:38 AM
goldenmatt
Jul 27, 2005 12:25 AM
