APPS connector question
Old Sep 21, 2013 | 08:40 PM
Hi Pockets's Avatar
Has anyone converted from the APPS that is located under the battery to the more common APPS that is located on the left side of the engine. I broke the connector and can not find a replacement.
Thanks for the help?
Old Sep 22, 2013 | 09:54 PM
rip 112's Avatar
Im afraid that type of Apps is a dealer only part, with the whole box and bellcrank included, about $450. They will also have the wiring pigtail as a dealer only part
However, I believe timbo may have some oem mopar units for much cheaper than dealer to replace the one under the battery. He sells them pretty quick so he may be out
Old Sep 23, 2013 | 08:06 AM
Hi Pockets's Avatar
Connector only
I have the APPS. I broke the connector that plugs into the unit. I will check with the dealer again. Thanks for the insight.
Old Sep 23, 2013 | 10:15 AM
gcssr's Avatar
If you have any wrecing yards around, you can probably find one there;;;
Old Sep 23, 2013 | 09:27 PM
Hi Pockets's Avatar
No luck so far. I've learned this was a CARB compliant truck. It went to CA. Not many of them here in CO.
Old Sep 23, 2013 | 11:49 PM
gcssr's Avatar
When i got my replacment from Timbo, he sent a pigtail adapter, you may contact him and see if he has the connector, Look up on the internet, google search;;;
ptgarcia
Sep 6, 2007 02:10 PM
Patrick Campbell
Mar 31, 2006 12:04 PM
RonP
Jan 30, 2006 04:48 PM
Diggem
Aug 29, 2005 09:49 PM
RAW FUEL
Jun 4, 2005 03:03 PM
