Anyone go from 3.73 to 4.10 after swapping to 35's? Opinions wanted.
Thinking about just paying for all new ring/pinion and install. Should have just found a truck on the lot with 4.10
. I'm at an effective 3.40 gear with my 315's.
Anyone do this?
Will dually axles off an 06 work on my truck if I change the hubs?
Thanks in advance
. I'm at an effective 3.40 gear with my 315's.Anyone do this?
Thanks in advance
You must tow allot or have a auto. I am happy with 37s and 3.73s. They keep the engine in a good rpm range on the highway. I then have 1st if I need extra towing power to start.
You might just try some extra power to help out.
I was thinking the same thought since I have 35" toyo's and 3.73 gearing.
I was thinking abount going to 4.56 gears to compensate.
Is that too much or has anyone out there done this?
By some simple math, once 35" tall tires are installed, on 3.73 gears, the gearing now is comparable to 2.64. In order to compensate for the 35" tires, the new ratio should be 5.25.
This is why I was contemplating with going to 4.56's.
Any thoughts.
Thanks,
JR
Any thoughts.
Thanks,
JR
Any thoughts.
Thanks,
JR
Any thoughts.
Thanks,
JR
robert chilton
27
Nov 3, 2005 12:23 PM
03CumminZ4X4
18
Feb 2, 2004 06:21 PM
