Any One Have?
Old Apr 13, 2007 | 05:56 PM
brickenbone's Avatar
Any One Have?
looking for a couple used injectors for 04.5 cummins.
Old Apr 13, 2007 | 07:21 PM
well i dont know how I could figure out if I needed just one. Right know I have one for sure that is not shutting off.It looses pressure when the key is off and takes a longer cranking start to build up pressure and start.Do you know if there is a way to check which one is bad?
Old Apr 13, 2007 | 10:28 PM
Foot Performanc's Avatar
if it idles up after sitting there a while if not you will need a cap off tool deal item as far as i know
if it does idle up and you dont wanna go to dealer or other shop i can walk you threw it
you will have to take off the valve cover and take off the wires at the injector and then set it back on see if it starts and doesnt idle upwhich ever on it does it on there you go
but this may not work it is just not very easy but you can take it to a shop have them cap each one off and pay a couple of hours diag time but then you can change the injector yourself
if you have anymore questions just as
clint80
Dec 11, 2011 01:15 PM
bullfrog5.9
Jan 31, 2008 01:49 PM
bthanks
Apr 13, 2007 02:27 AM
JIT
Jan 15, 2007 11:43 AM
Mopar_Mudder
Nov 1, 2002 07:42 AM
