Any major issues w/ 03' CTD ????
Old Feb 20, 2006 | 06:28 PM
HydraulicGuy's Avatar
After owning & driving my 00' for 200,000 miles, dealing w/ tranny problems, fuel pump problems, ball joints etc., I dove into an 03' H.O. w/ a 6 speed. I almost went over the edge (I hate to admit it) I did look at a few Fords and G.M.s. I hope I do not get kicked out of the club for just looking. With a bit of research I came to the conclusion that they all have their own issues so I stayed with the Cummins. So far I'm petty happy about it. It sure drives nice. I plan on putting my gauges in as soon as I find a place to put em (Any suggestions?) My biggest concern is the lift pump. I was looking around for it and could not locate it. My best guess it's in the tank. I'm guessing I will be dealing with the same problems witht the lift pump as I had with my old one. I went through 4 stock lift pumps in 200,000 miles. I went to the 6 speed manual to get away from the auto problems. For some reason every automatic I've driven for a period of time has shelled out. Must be my driving habits.(?) Any issues with the 6 speed? Any other advice is appreaciated. I hope you all will let me be in the 3rd generation club. I have paid my dues.
Thanks!
Old Feb 20, 2006 | 07:17 PM
Lrdchaos's Avatar
Well you will be happy to know that the 03 you bought has the same frame mounted fuel pump your 00 had....they changed in 05
Old Feb 20, 2006 | 08:45 PM
SafeHarbor's Avatar
My 03 has the pump mounted on the rear side of the fuel filter cannister.
Lamar
Old Feb 20, 2006 | 09:07 PM
PsRumors's Avatar
The only problem I have had is the rear u-joint. That is a manual problem from what I hear. Other than that you should be just fine.
Old Feb 20, 2006 | 09:23 PM
My 00' lift pump was behind the fuel filter on the engine. I may not have looked close enough for it on the 03'. Regardless, if it is the same that just sucks. I was looking at a FOSS unit or the notorious WALBORO unit for my 00' before I sold it. Jegs has a kit as well but I'm not sure who's pump it is.
Thanks for the reply.
Hydraulicguy
Old Feb 20, 2006 | 09:31 PM
pullin hard's Avatar
yup, pump is in the same spot as your 2000.
but i think they are a little better, because not as many problems as those noisier 2000 and 2001's
when it goes, or even before it does, get a Fass, or something similar and you won't look back.
Old Feb 20, 2006 | 09:39 PM
kertoncol's Avatar
So, far they replaced the driveshaft and u-joints, front left u-joint. I have a small vibration (think the carrier bearing needs to be lowered). During temps under 30 I have a owl 'who-ing' noise at about 23mph. Dealer says they can't hear it. Other than that I'm happy with the truck.
Johnmesich
Jun 28, 2012 12:07 AM
Firstgenfanatic
Sep 3, 2009 04:21 PM
2500
Oct 11, 2006 04:28 PM
10secBu
Mar 15, 2004 09:19 PM
Jeff in TD
Jan 7, 2004 10:13 PM
