Another Jake brake question
Old May 30, 2007 | 06:59 PM
HOV's Avatar
HOV
This is my first exhaust brake, and I didn't know what to expect. Questions for the gurus:
Should it make a loud air pssssssssssssst when it engages?
Does it put the transmission in a shift and lockup pattern similar to tow/haul? I noticed 4th gear lockup at 47 MPH, and the trans holds lockup longer and at lower speeds.
Old May 30, 2007 | 07:27 PM
ptgarcia's Avatar
Yes and yes. Sounds like it's working right to me.
Old May 30, 2007 | 07:41 PM
HOV's Avatar
HOV
Thanks for the reply.
And I assume the braking effect increases on declines and with lower gearing, due to more force being applied on the pistons from gravity, momentum, and leverage? I was surprised at first when, on flats, it feels just like letting your foot off the throttle of a gasser.
Old May 30, 2007 | 07:50 PM
rustyshakelford's Avatar
higher RPMs met more braking hp. it takes a little getting used to, but once you are you sure notice when its not on.
brett
Old May 31, 2007 | 09:11 AM
carharttfarmer's Avatar
sound like its right to me hiss can get anoying in town with the windows down on mine
Old May 31, 2007 | 10:35 PM
TonyB's Avatar
On easy throttle...i.e. shifting at 1700-1800 in 1-2, 3rd should lock up about 30-32mph.
Tony
dws35
May 4, 2007 10:42 AM
wvcowhauler
13
Apr 3, 2005 11:39 PM
newtattoobob
43
Jun 12, 2003 11:13 AM
