amsoil /traneyfluid
Old Feb 1, 2010 | 10:25 AM
sotex's Avatar
amsoil /traneyfluid
wanting to change to amsoil traney fluid .having to drop traney pan to replace1st to second presure selonoide an posible v/b.any sugestons on any thing i might need to check on.also is a wick traney filter ok or should i use stock?sotex
Old Feb 1, 2010 | 02:05 PM
92'1stGen's Avatar
I'd skip the Amsoil tranny fluid as you'd be wasting money dumping it every 25 - 30k, which is about the length of time you should be going between dropping the pan, changing the filter, and replacing the fluid that came out. Just buy some Mopar ATF4+ from the dealer or get some Valvoline ATF4+ from Autozone, it'll be fine.
Old Feb 1, 2010 | 03:13 PM
DBLR's Avatar
As for the trans filter I used Mopar as I could not buy one at Napa, they told me my trans was not listed in there book. As for the ATF I used Amsoil and like that its 100% synthetic. FYI Mopar ATF is made from dino group III base stock.
Old Feb 1, 2010 | 05:03 PM
sotex's Avatar
traney fluid
startrted runing amsoil a while back in my o4 motor .oil analysers i have used showed good results .very hot in this part of the country amsoil claming to run 50 degres cooler. so ma be worth a trie. any one heard of this. also changing fluid 25 to30 thousand miles is somthing i may not be wiling to do so ofton .seeing i only toe 16 foot trailer with4 four whelers.sotex
Old Feb 1, 2010 | 10:22 PM
J.Suplanski's Avatar
Thumbs up Amsoil ATF
Amsoil says you can go 100,000 miles between changes, I go 75,000
Old Feb 2, 2010 | 08:43 AM
1985cucv's Avatar
ams oil is awesome i am going to do mine every 40k prolly maybe 25k
Old Feb 2, 2010 | 02:23 PM
92'1stGen's Avatar
I highly doubt you'll see a 50 degree difference in trans temps simply from using a different fluid. Numbers like that are the kind you get from adding a secondary fluid cooler. I wasn't basing changing intervals off of how much you tow. Whether you daily drive or tow at you max weight limit, it's a good idea to keep the fluid fresh in the transmission, especially since the filters for these transmission are more like screens than filters. It's a lot easier to do that than deal with return hose's and getting in and out of the truck to start and stop it for a full flush at double that rate.
Spooler
28
Dec 26, 2009 10:16 AM
czkid
Oct 18, 2007 07:38 PM
OH Sick
25
Feb 27, 2007 12:39 PM
Fishcop
Nov 25, 2002 09:10 PM
