Amsoil BMK-13
Old Feb 8, 2008 | 08:46 PM
gildere's Avatar
Amsoil BMK-13
Can we use these for our newer 5.9's? I want to get the full flow filter some where I can get to it easier.
Eddy
Old Feb 10, 2008 | 03:39 PM
DBLR's Avatar
No you should only to use the BMK-11 on 04 and newer engines. IIRC Amsoil noticed the other By pass units like the BMK-15 etc. lowered the oil pressure on the newer engines and they only recommend the BMK-11 to be used. So if you did use the BMK-16 and it lowered the oil pressure an you then you had engine problems related to low oil pressure then warranty would not cover the repair work nor would Amsoil.
Old Feb 10, 2008 | 05:06 PM
rjm022's Avatar
dblr is correct.
https://www.dieseltruckresource.com/...9&d=1167438120
kprc51
Dec 31, 2007 12:54 PM
Arkapigdiesel
32
Aug 21, 2007 08:00 PM
FirstDodge
Mar 9, 2007 06:29 PM
rjm022
Oct 2, 2006 03:59 AM
dogger
Nov 16, 2004 07:24 AM
