Am I doing it wrong?
Old Apr 20, 2008 | 03:17 AM
gomulego's Avatar
Do I need to re-read the manual?
My neighbor came over today to tell me he got his S10 stuck in the mud in my field and asked if I could pull him out (it's ok, I go in his fields too). I said sure and we took the Dodge. It was pretty soft and so I locked it into 4 wheel low and went into the field. I didn't have any trouble pulling him out, but when I came out of the field the truck wouldn't go back into 2 wheel (or anything else) without grinding big time. It didn't matter if I was stopped, in park, in neutral..whatever. I finally had to just shut it off altogether to shift it out of 4 wheel. That doesn't seem right. I have an old toyota 4Runner that goes in and out on the fly if you want.
What am I missing?
Old Apr 20, 2008 | 05:52 AM
Jeff in TD's Avatar
You might find sometimes you have to back up a little bit, to take the torque load off between the axles so the transfer case can shift...
Old Apr 20, 2008 | 06:48 AM
Hounddog's Avatar
Moving slightly helps sometimes.
Old Apr 20, 2008 | 09:43 AM
FlaCracker's Avatar
That is odd, I have never had that problem. Like said above, make sure there is no weight on the truck, i.e., on an incline, ect., when you try to shift out. If it still does it I would get it checked, not normal.
Old Apr 20, 2008 | 09:44 AM
jrussell's Avatar
Do you have the push button 4wd system or the manual shifter?
Totallyrad
Oct 12, 2007 01:22 PM
Common
19
Jul 31, 2007 05:33 PM
schv
Jan 17, 2007 09:02 PM
Fronty Owner
Nov 29, 2005 07:38 PM
PumpDaddy
Jan 11, 2004 08:10 PM
