Alternator issues
Old Jun 28, 2013 | 01:40 AM
ironbrew's Avatar
Alternator issues
Ok. Three alternators. Voltage Gauge drops to zero when heavy draw. Any ideas? Just starting a major road trip. Thought replacing alternators would fix it. Truck is an 04.5, electric fans, 5% injectors, stage 2 cam.
Old Jun 28, 2013 | 07:08 AM
Hintonc393's Avatar
Check your battery connections very carefully, take them off and clean them even if they look fine. Have you load tested the batteries? I think the ECM reads voltage off the left side battery, your alternator is ECM controlled. Wouldn't hurt to swap batteries from left to right and see what happens.
Old Jun 28, 2013 | 07:46 AM
ironbrew's Avatar
I'll try the battery swap.
New positive cables. New ends on the negative cables. Soldered ends. New alternator to battery cable. New batteries.
I can watch the voltage through the OBDII as I drive (edge insight), and it never goes above 13.5 however when there is a load it starts to drop, and when it gets to the low 12's, the alternator turns off.
Old Jun 28, 2013 | 02:02 PM
ironbrew's Avatar
Ok. Solved, I think.
Changed the wire from alternator to battery to a 1/0 cable. Voltage up, truck running awesome. Thanks.
jbritvar
Mar 31, 2013 11:21 PM
walexa
Oct 19, 2012 07:33 PM
Huntsville 3500
Mar 9, 2010 09:23 AM
banks twinram
Jul 23, 2009 09:39 PM
5.9Excursion
Mar 13, 2008 07:08 AM
