additive = rough idle WHY
Old Dec 10, 2007 | 06:49 PM
2happy's Avatar
I got a good one….When I add Opti-Lube XPD, Amsoil Diesel Concentrate or Power Service Diesel Kleen + Cetane Boost, my truck has a rough idle and hard first crank. It goes back to smooth idle and easy crank when no additive. The only thing that I have put in it that has not caused any issues is Lucas Upper Cylinder Lubricant. Truck has 84K on it and is stock except for what is the signature below. Can any of you good people provide any advice on this???? Thanks in advance for the help.
Old Dec 10, 2007 | 06:53 PM
CamperAndy's Avatar
We need to know what you have. Guessing it is a newer truck but more details would help.
BTW I see no signature.
Old Dec 10, 2007 | 06:54 PM
CowboyDave's Avatar
Cant help you, But welcome to DTR!!! Also it might help some people help you with youre problem and future probs if you fill out your sig with the trucks make and mods.
Old Dec 10, 2007 | 07:28 PM
2happy's Avatar
Sorry guys, first time posting and thought I had a profile on showing on the truck, here is what I got.....'04 2500 4x4 Quad Cab black, auto,3:73 gears,305/65/17 BF AT KO,FASS,PSM Cold Air Intake,Red COOL Hose=no silencer ring,Amsoil by-pass oil kit(no black oil)SRT Hood,BIG Mouth Grill,LED tail lights,ARE top,EMS Off Road Hub Conversion Kit(4 MPG gain),Rancho RS9000X Shocks
Old Dec 10, 2007 | 08:33 PM
FlaCracker's Avatar
I started using Power Service when I bought my truck new, then switched to Howes Meaner Kleaner, and am now using Stanadyne Jr Diesel fuel treatment. I have not had any problems with any of these products.
Old Dec 10, 2007 | 08:43 PM
MikeyB's Avatar
My guess is the cetane boosters maybe causing the longer cold starts and the rougher idle. Try cutting back on the boosters and see if it makes a difference.
MikeyB
Old Dec 10, 2007 | 09:27 PM
bluebull's Avatar
Originally Posted by 2happy
'04 2500 4x4 Quad Cab black, auto,3:73 gears,EMS Off Road Hub Conversion Kit(4 MPG gain),
Sorry I can not help with your question but I have one for you if you don't mind.
EMS has a conversion kit for the AAM axles?
Could I get a rough Estimate of what it cost you for the kit and installation?
4 MPG gain would be great.
Thanks,
Old Dec 10, 2007 | 10:02 PM
2happy's Avatar
bluebull, the kit is 1295.00, this is the lighter duty kit, I did not need anything any heavier. Also could tell a difference in steering for the better. http://www.emsoffroad.com/products/hubconvert.htm
Old Dec 10, 2007 | 10:05 PM
2happy's Avatar
Another thing, i can say how hard to install, i had it done, so if you take that route add $$$
Old Dec 11, 2007 | 10:12 AM
bluebull's Avatar
2happy,
Thank you for the response and the link. Very helpful.
Old Dec 11, 2007 | 11:45 AM
Roperteacher's Avatar
I have used pretty much all the additives at some point. I really like the opti Lube. The only rough Idle I had was with the summer blend and all I did was add a little PS to it and it smoothed right out. Hope that helps!!
Old Dec 11, 2007 | 12:55 PM
DBLR's Avatar
How much are you adding to your tank? It could be your putting in to much additive in to your fuel and that can cause problems. Are you mixing all of them together or trying them one at a time? IIRC you only use 10 oz of Power Service to 34 gallons of diesel. I also use 6-8 oz of Lucas 1 or 2 times a month just to keep the injectors clean.
Old Dec 11, 2007 | 02:38 PM
RBulldogger's Avatar
Please elaborate.
Old Dec 12, 2007 | 09:01 AM
2happy's Avatar
I don’t do overkill, for example yesterday on the way to VA, I put in 6oz of Howe’s Meaner Power Kleaner to see if it would work and still have rough idle. And I have not mixed the additives.
Old Dec 12, 2007 | 09:14 AM
Opti lube is 1/2 ounce per gallon for the XPD and 1 ounce for 20 gallons on the Summer blend!! It's like Syrup!
