Add 2nd 7 way plug in bed
Old Dec 28, 2005 | 03:36 PM
PZM123's Avatar
Curt Manufacturing has a T-connector ( #55381 ) for 00/05 trucks. I looked for months & could not find one. Seen guys were cutting & splicing there harness.Didn't want to do that sooner or later arthritis will set in. Got the T-connector a Bargman 7 way sealed car end cable & used heat shrink butt connectors. It's as weather tight as it gets. After you put it together in the garage it's plug & play. Hope this helps someone.
Old Dec 28, 2005 | 03:57 PM
Fat Framer's Avatar
#55381 is for a 1500 ram. I wonder if it will fit the 2500 and 3500?
Old Dec 28, 2005 | 05:30 PM
PZM123's Avatar
Yes if you have the oem tow pack. I have a 3500. The T-connector says it's for 2000/03 pickups but the plugs are the same.Did I mention it only has a flat 4 plug? I spliced into the extra wires on the T-connector not my truck.
Old Dec 30, 2005 | 10:39 PM
Childofthewind's Avatar
Where does this connect in?
Does it give you all 7 lines?
Old Dec 31, 2005 | 06:29 AM
PZM123's Avatar
Childofthewine I reposted this in the Towing & Hauling/RV forum with a little more detail. Feel free to shut any questions back or PM me if you need.
Hoss
Mar 22, 2023 08:51 AM
dodgemaniac
Jun 12, 2007 08:21 AM
PZM123
Feb 10, 2005 06:23 PM
