AC Compressor Won't Stay Engaged
Old Apr 15, 2015 | 01:12 PM
SimpleSailor's Avatar
I have an '06 5.9. The fan blows good and strong but when I turn the AC on the compressor tries to start but won't. It kicks on for 1-2 secs then off for 1-2 secs then on, off, on, off. Then it just doesn't try anymore and stays off. Any thoughts, first step suggestions or the like? thanks.
Old Apr 15, 2015 | 04:04 PM
sherod's Avatar
Sounds to me that you are low on freon. If that doesn't fix it, the pressure switch could be going.
Old Apr 15, 2015 | 04:23 PM
I thought it might be low on freon so I bought one of those little cans from the parts store that came with a gauge. The compressor has to be running for it to work. So I had someone turn the AC on so I could add the freon while the compressor cycled on and off quickly beforevit stopped. When I attached the can to the truck line it read over 100 psi and couldn't take freon as the pressure was too high. Probably because the compressor wouldn't engage or whatever the underlying problem is. More advice is greatly appreciated.
Old Apr 16, 2015 | 08:00 AM
patdaly's Avatar
Hate to say it, but it is time to take it to a AC guy.
Without a good set of accurate gauges on both sides, you are weeing into the wind.
Old Apr 18, 2015 | 08:45 PM
dirty pete's Avatar
This happened to me last summer on my 03 one ton.Did you read the directions on the can? ( I usually read the directions while the glue dries.) But read the directions,those cans tell you what to do .It worked for me,and I'am not a mechanic,but I got cold air.GOOD LUCK with it and let us know what works.
Old Apr 20, 2015 | 07:41 AM
PWong's Avatar
The pressure should drops when compressor kicks in even for a couple of seconds.
If the pressure didn't drop then something wrong the hookup.
Old Apr 20, 2015 | 06:09 PM
dirty pete's Avatar
Just checking. Did you hook to the low side and not the high side?
Old Apr 20, 2015 | 07:59 PM
patdaly's Avatar
On R134, sizes are physically different from high to low.
Old Apr 21, 2015 | 07:18 PM
dirty pete's Avatar
Just checking.
Old Apr 24, 2015 | 01:52 PM
jeephauler's Avatar
Check to ensure the compressor clutch is not shot. This ended up being my problem and a realatively easy repair. There is a thread on here somewhere that is very helpful and even provides part numbers and sources.
Old Apr 26, 2015 | 06:59 PM
dirty pete's Avatar
Did you ever figure this out ?
bamadzl
Aug 17, 2014 10:34 PM
BrdDawg
Jun 24, 2005 09:33 AM
lyvwire
Jan 13, 2005 07:54 AM
JRS240
Jan 29, 2004 08:06 PM
ARAcummins
Oct 22, 2003 03:51 AM
