Ac blues
Old Jul 23, 2023 | 10:15 AM
James M Goodwin's Avatar
Ac blues
Having issues with ac spent over 4000 on ac parts and still no cold air
Old Jul 23, 2023 | 02:03 PM
westcoaster's Avatar
Well, that sucks....
Old Jul 24, 2023 | 12:31 AM
yes it socks big time, actually really sucks cause it's my father's truck just trying to help him out.
Old Jul 24, 2023 | 09:31 PM
That's pretty cool!
err.....
I mean, not in the cold-cool sense....
If you are here to vent, that's ok, we can all commiserate together.
If you are looking for assistance on trying to solve your father's AC issues, well, you are going to have to risk getting muscle cramps in your fingers as we are going to need A LOT more info....
Old Aug 2, 2023 | 09:56 PM
Yes I understand, not really sure what all got changed after I had installed compressor,, dryer but anyway I had changed compressor dryer and pulled vacuum charged the system and everything seemed to work fine father told me the next day it was cooling than ever and then the following day was just blowing hot air.
Old Aug 2, 2023 | 09:58 PM
He took it to an older guy and spent a barrel of money and now the poor fellow has passed away.
Old Aug 3, 2023 | 03:24 PM
Mexstan's Avatar
If it was cooling one day and not the next, suspect that the system has developed a massive leak. Suggest that you re-check the pressures.
Old Aug 3, 2023 | 03:45 PM
47Dodge's Avatar
Sounds like a leak to me too! Vacuum down and let it sit a while to see if it leaks off....................
47
Old Aug 11, 2023 | 02:40 PM
haily grace's Avatar
Did you try to change the filters ?
Old Aug 11, 2023 | 03:41 PM
Mexstan's Avatar
Which filters are you referring to? Please elaborate how changing any sort of filter would make this work. After changing the filter, what would you recommend as the next steps? Very curious as to how you arrived at this conclusion for the fix.
Old Dec 28, 2023 | 09:27 AM
vanman's Avatar
Is it no air at all or just warm air? If no air at all, check the blend doors. If warm air, check the pressures to start with. High and low.
pipergsd
Sep 2, 2010 11:17 PM
cj5er
Apr 15, 2009 11:22 AM
mysterync
Nov 26, 2006 04:32 PM
