ac
Old Sep 14, 2009 | 07:23 AM
ddwc52's Avatar
ac
having problems with ac no defrost no air at floor level seems like ac is freezing up pulled out glove box looks like recirc ulating door is working do i have a vachumn problem does anyone know where vachumn pump is 2003 dodge cummins 136000 miles all stock
Old Sep 14, 2009 | 12:33 PM
ssandlin's Avatar
Based on that statement, I'd guess you have a broken mode door.
Old Sep 16, 2009 | 01:06 AM
lawdog79's Avatar
I had issues with my A/C, dealing with different problems. But when I was talking to my friend, who is a diesel mechanic at a dealership, he told me that the broken doors are a fairly common problem.
Old Sep 16, 2009 | 06:00 AM
ddwc52's Avatar
lawdog 79 thank you for info
Old Sep 16, 2009 | 06:16 AM
BPM's Avatar
BPM
From: Shreveport LA for 10 days at a time, Groveton TX the rest
Definately sounds like a broken door. FWIW there is no vacuum pump on an 03. Found that out when my dad's power steering pump went out and he lost his brakes. Just thought you might want to know.
Old Sep 16, 2009 | 06:30 AM
ddwc52's Avatar
thank you bpm for info
Old Sep 16, 2009 | 04:31 PM
xyzer's Avatar
Probably the door but for future reference the "03" has a vacuum pump on the passenger fender well used for cruise control.
Old Sep 16, 2009 | 06:06 PM
ddwc52's Avatar
thanks everyone for the info
Old Sep 19, 2009 | 06:33 AM
Jeff in TD's Avatar
Does the floor/defrost stuff work fine at first, then quit after an hour or so running on AC in really hot temps?
In that case, the evaporator may be freezing up. Moving the temp sensor may help, and you would also want to make sure the drain is clear.
If on the other hand you don't have defrost or air to the floor when put in those modes right off the bat, then you likely have broken doors inside the housing.
THis thread may be helpful.
https://www.dieseltruckresource.com/....html?t=210483
Old Sep 20, 2009 | 05:52 AM
jpfishmaster's Avatar
Broken door or door motor; had the same issues a few months ago.
