ABS Code
Old Sep 22, 2005 | 02:03 PM
kingofdodge7131's Avatar
ABS Code
My ABS light has come on, Do i need a special code reader to find this? My lil 30 dollar sears special doesnt seem to see them.
Old Sep 22, 2005 | 04:17 PM
doorguy's Avatar
did you try the the key trick to see if it shows any codes in your odometer.(turn the key on and then off three times with out starting) If that does not work probably need drbIII to read it.
Old Sep 22, 2005 | 11:19 PM
whats drbIII, where do i pick one up at?
Old Sep 22, 2005 | 11:39 PM
RamWheelsBy4's Avatar
DRBII tool is typically a dealer only tool. Some garages may have one, but not many. Did you get a code, when you turn the key from off to on three times? Any codes will display in order on the OD readout and the work done will display when complete.
Old Sep 23, 2005 | 05:21 AM
N.Johnson's Avatar
Last time I checked these things retailed for around 6000.00 bucks. Still want one?
fitzydog
21
Oct 11, 2017 12:09 PM
DodgeRam24V
0
Jan 7, 2012 06:02 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
