ABS/Brake light! .....again.
Old Aug 24, 2009 | 04:47 PM
dslpwr81's Avatar
Hello all. This weekend while out hunten, I was driving on a dirt road about 40mph and hit a massive pot hole in the road. Both the front and rear end slammed into this thing. Immediately after, my abs and brake light came on. Everything else works with the truck, and it still drives straight down the highway. I looked and looked for something broke such as a sensor on the diffs. I found nothing. I did a search and while there are tons of threads on this, I couldn't quite find what I was looking for. So, instead of continuing to spend hours and hours under my truck, maybe you guys can help.
Thanks
Jason
Old Aug 24, 2009 | 05:30 PM
# 1 FAN's Avatar
I had this happen to me about 5 mo. ago and lights went off a couple starts later. Just yesterday my wife said it came on 3 days in a row. So i would like to see where this thread goes.
Old Aug 24, 2009 | 05:38 PM
Scottie250's Avatar
Same thing happened to me. I found a smashed wire insulator around the overload bumper under the truck leading to the sensor. After peeling back the insulator, I noticed the wire inside had been severed without an exterior cut to the insulator. I spliced the two wires together, wrapped with electrical tape, problem solved. Hope this helps.
Old Aug 24, 2009 | 05:54 PM
billie's Avatar
Is there a code? A F**D i had would at least tell you what to look for.
Old Aug 24, 2009 | 10:58 PM
dslpwr81's Avatar
You bet!!! A few hours after posting this, I found the problem. I have dual exhaust under my truck and they hang some what close to the rear diff. Well, after looking under my truck, I noticed that I have a major dent in my exhaust. Huh? I hit that pot hole so hard, my rear end came up and slammed into the exhaust Y. I too peeled back the wire loom 2 inches from the sensor, and sure enough, smashed wires. After looking at the wires closerone of them was cut in half. Now I'm hoping thats all the damage I did to it. Lol.
Thanks
Old Aug 24, 2009 | 11:20 PM
# 1 FAN's Avatar
Thanks
Where is this wire at??
Old Aug 25, 2009 | 10:30 AM
dslpwr81's Avatar
Its the wire loom that comes off the sensor right on top of the rear diff.
Old Aug 28, 2009 | 01:06 PM
# 1 FAN's Avatar
Thanks,I will take a look..
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
