ABS brake light
Old Mar 21, 2012 | 09:29 PM
johndeere01's Avatar
ABS brake light
Hey guys been awhile since i posted my buddies 05 ABS and brake light are on changed one wheel bearing thinking that was the problem light went out for a few days then came back on. The other wheel bearing is only 5 months old and still tight. All the conections are good on the wires and i cant pull any codes with my smarty any ideas?
thanks Dennis
Old Mar 21, 2012 | 10:26 PM
BigIron70's Avatar
Cummins Guru
scan tool needed to pull code. You could pull the rear sensor and check resistance. If all the fuses check good that is. Sensor resistance should be approximately 1600–2300 ohms at 76 degrees F if not then replace sensor.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
